FSola1
7 years agoHow to access files on the SD Card from a bare metal application?
Hello; I am currently writing a C program, in a bare metal approach (I need bare metal due performance restrictions), currently I am able to transfer data from the C program to the FPGA . The board ...
Ahmed_H_Intel1
7 years agoHi,
Are you using the SD card in booting? Can you share the SD card format?
I will check if this needs a certain driver to control the SD card.
FSola1
7 years agoHi,
Yes I am booting from the SD card using the preloader, that loads u-boot, and then it loads the bare metal C program to the HPS, and the .rbf code to program the FPGA as well.
Here is the SD Layout I am using
