How do I program the KAK (Key Authorization Key) in User Access Fuses (UAF).
Hi ,
You can refer the to the application note below for programming the fuses with keys.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf
Also as mentioned in the Intel Arria 10 Soc Secure Boot Guide use the Intel® FPGA Download Cable and the programmer tool installed with the Design Tool Suite.
Thanks and Regards
Anil
- KKlei56 years ago
Thank you for the reply.
I already know how to program the AES key for securing the FPGA programming file. As I mentioned, it is done with a .ekp file just as your referenced app note indicates. My question was how to program the KAK / Root Public Key / SHA256 of the public key, which is used to authenticate the 2nd stage boot loader. Can you point out which section of this app note describes the KAK / Root Public Key / SHA256 of the public key, and specifically how it is programmed, such as by .ekp file or other?
