FPGA On-Chip Memory Initialization with Preloader
We recommend user to use Linux when building the booting binaries; please refer below documentation on the steps:
https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Cyclone_V_SoC_45_Boot_from_SD_Card
- Campbell5 years ago
Hello and thank you for your response,
I understand that the preloader generation process works best on Linux however I would like to carry out the process on Windows if at all possible. I already have a significant amount of the project set up on Windows and I believe it will be easier for people in my organization to follow my design example on Windows.
Campbell
- EBERLAZARE_I_Intel5 years ago
If you insist on using the Windows environment to build, then you might need to use version 19.1/19.3 to compile and build in Windows.
I think this issue may extend beyond just the Preloader.
I tried to initialize a second on-chip memory component with a .hex file containing the HPS bare-metal application image. I converted the application-mkimage.bin file (which I confirmed works when booting from the SD card) to a .hex file with the following command in the Embedded Command Shell version 17.0:
$ arm-altera-eabi-objcopy -I binary -O ihex --adjust-vma -0xc0000000 application-mkimage.bin application.hex
When trying to recompile the project so that the preloader.hex and application.hex files are actually synthesized in the FPGA memory, I get the same error as before. When I rename application.hex so that Quartus can't find the memory initialization file, the error goes away.
Note that I was actually able to use the Altera Embedded Command Shell version 17.0 to generate the Preloader and convert it to a .hex file without errors.
I also tried changing the size of the on-chip memory component that contains the application.hex file to be much greater than the size of the file and still got the same error.
I have attached the application.hex file (converted to a text document) for anyone interested. The beginning and the end of the file are similar to the preloader.hex file that I couldn't synthesize in memory (these sections are missing from the preloader.hex file that did work without error)
