hasssanadeli
2 years agoFPGA clock frequency
Hello, To program the FPGA of MitySom-5CSX, I was wondering if could anyone tell me the FPGA clock frequency pin number and its value. I tried 50MHz and AA8 pin number but it did not work. Thanks,
FvM
2 years agoHi,
letting Quartus select a clock has the disadvantage that Quartus knows nothing about MitySOM-5CSX SoC module and which FPGA clock pins are exposed to the module connector. You want to review datasheet or design guide to learn about available clock inputs.
Datasheet reveals that all global clock pins except clk4 p/n and clk5 p/n are available, to gether with respective FPGA and module pin number.
Intended usage of FPGA IO banks in your application probably results in preferences for clock pin selection.
