error when debug an exercise sample application on A10 SOC board
- 3 years ago
i found the root cause, the error is caused by the too early exit of uboot spl debugger bufore excecuting the app.
now i understand the app depends on the hardware initialization by the uboot spl.
so after successful running uboot spl, i disconnected the target and run the app examples immediately and it also succeed.
thanks.
Hello Rainwang,
Hope this query finds you well. I am facing the same issue while trying to use Arria 10 SoC for baremetal programming. I am using SOCEDS and ARM DS5. I am trying to execute the sample program that already given with SOCEDS package itself. But i am also getting the same error and can you please let me know how you resolved this issue. Thanks in advance.
- Rainwang3 years ago
Contributor
pls see my solution, you need to run the uboot spl firstly then switch to app, because the app depens on spl to initialize the environment.
- Itzthiru3 years ago
Can you please let me know in which machine you've tried whether in windows or Linux machine and help me with the below issues also?
When I try to execute bare-metal sample programs for the Arria 10 SoC on Windows using Arm-DS IDE, I encounter the following error message:
Target Message: Memory access caused precise abort. Debug Precise Abort Registers : DFSR = 0x00000817, DFAR = 0xFFFF2000 ERROR(TAD11-NAL18): ! Failed to write 4 bytes to address S:0xFFFF2000 ! Bus error on memory operation
After that from my understanding, I am getting that error because of booloader and I attempted to build the bootloader for Arria 10 SoC in a Linux environment using VirtualBox on my Windows machine. However, during the build process, I am getting the following error:
make socfpga_arria10_defconfig.
makefile:40: *** missing separator. Stop.
I have completed the installation and now i am working on the DMA of HPS component. Can you share any example files for toggling HPS LEDS in Arria 10 using direct memory access or i need to configure something before?
