MCOUNSELL
7 years agoError: The target hardware identity could not be verified. Please check that the target being connected to is of type Cyclone V SoC (Dual Core)
HI all, Noob here... I'm just getting started with Cyclone 5 SoC based dev. I have a De10-Nano board. I can program the FPGA section from Quartus without problem. I can run HelloWorld from DS5 ....
EBERLAZARE_I_Intel
7 years agoHi,
Are you trying to run a bare metal program?
From Debug Configurations > Connection tab, select Altera > Cyclone V SoC (Dual Core) from the Target Connection.
Recommend if you are trying to run the bare metal program you can refer here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_bm.pdf
Regards.
MCOUNSELL
7 years agoHi,
Thanks for your response.
Yes, it's a bare metal program. I have the bare metal PDF already thanks.
Can I ask if there are any bugs in the debugging through DS5 + USB Blaster setup? ..... is it rock solid... or flakey.... I'm just trying to understand if this kinda stuff is normal or if I am doing something very wrong...
Mike
