Salma_M_Intel
6 years agoError programming Intel Stratix 10 MX FPGA Dev Kit (A PMBUS error has occurred during configuration)
Here is the error. I will attach the qsf file subsequently. Info: Command: quartus_pgm -c 1 --mode=jtag top.cdf Info (213045): Using programming cable "Intel Stratix 10 MX FPGA Development Kit [1-1...
YuanLi_S_Intel
6 years agoHi Salma,
Based on the erro message, seems like inapropriate VID setting is set on your design. Can you please check on it?
You may refer to the Stratix 10 VID setting user guide at link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-pwr.pdf
Thank You
