Error occurred when build the u-boot
- 4 years ago
it seemed work today.
in fact , i was looking for the solution to support the usb blaster under WSL2, what i did is as below:
1. My platform: WSL2 + ubuntu 18.04 on windows 10
2. to support USB blaster on WSL2, i upgraded the linux kernel from 5.10.16.3 to 5.10.60.1.
3. checked the specification Intel® FPGA Software Installation and Licensing, found some dependencies need to be installed.
from /var/log/dpkg.log, i upgraded below packages, not sure which one is root cause
at last, the usb blaster still can't work on ubuntu, but i found the u-boot now can be made successfully.
2022-08-17 14:57:23 install liblzma-dev:amd64 <none> 5.2.2-1.3ubuntu0.1
2022-08-17 15:27:33 install lib32tinfo5:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:27:33 install lib32ncurses5:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:42:05 install zlib1g-dev:amd64 <none> 1:1.2.11.dfsg-0ubuntu2.1
2022-08-17 15:57:17 install libtinfo-dev:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:57:17 install libncurses5-dev:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:57:17 install u-boot-tools:amd64 <none> 2020.10+dfsg-1ubuntu0~18.04.2
2022-08-17 15:57:17 install device-tree-compiler:amd64 <none> 1.4.5-3
2022-08-17 15:57:17 install libattr1-dev:amd64 <none> 1:2.4.47-2build1
2022-08-17 15:57:17 install libacl1-dev:amd64 <none> 2.2.52-3build1
2022-08-17 15:57:17 install uuid-dev:amd64 <none> 2.31.1-0.4ubuntu3.7
2022-08-17 16:06:50 install libdouble-conversion1:amd64 <none> 2.0.1-4ubuntu1
2022-08-17 16:06:50 install libqt5core5a:amd64 <none> 5.9.5+dfsg-0ubuntu2.6
2022-08-17 16:06:50 install libqt5dbus5:amd64 <none> 5.9.5+dfsg-0ubuntu2.6
2022-08-17 16:06:50 install libqt5network5:amd64 <none> 5.9.5+dfsg-0ubuntu2.6
2022-08-17 16:06:51 install libqt5qml5:amd64 <none> 5.9.5-0ubuntu1.1
2022-08-17 16:06:51 install qttranslations5-l10n:all <none> 5.9.5-0ubuntu1
2022-08-17 16:10:21 install libc6-dev-i386:amd64 <none> 2.27-3ubuntu1.6
2022-08-17 16:10:21 install libc6-x32:amd64 <none> 2.27-3ubuntu1.6
2022-08-17 16:10:21 install libc6-dev-x32:amd64 <none> 2.27-3ubuntu1.6
2022-08-17 16:10:22 install libx32gcc1:amd64 <none> 1:8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32gomp1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32gomp1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32itm1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32itm1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32atomic1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32atomic1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32asan4:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32asan4:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install lib32ubsan0:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32stdc++6:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32ubsan0:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install lib32cilkrts5:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32cilkrts5:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install lib32mpx2:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32quadmath0:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32quadmath0:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32gcc-7-dev:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32gcc-7-dev:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install gcc-7-multilib:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:23 install gcc-multilib:amd64 <none> 4:7.4.0-1ubuntu2.3
2022-08-17 16:32:30 install libpng12-0-udeb:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 16:39:07 install libpng12-0-udeb:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 16:42:55 install zlib1g-udeb:amd64 <none> 1:1.2.8.dfsg-1ubuntu1
2022-08-17 16:47:55 install libpng12-0-udeb:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 16:53:54 install libpng12-0:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 18:05:41 install gcc-8-base:i386 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 18:05:41 install libgcc1:i386 <none> 1:8.4.0-1ubuntu1~18.04
2022-08-17 18:05:41 install libc6:i386 <none> 2.27-3ubuntu1.6
2022-08-17 18:05:41 install libbz2-1.0:i386 <none> 1.0.6-8.1ubuntu0.2
2022-08-17 18:06:28 install libtinfo5:i386 <none> 6.1-1ubuntu1.18.04
2022-08-17 18:06:28 install libncurses5:i386 <none> 6.1-1ubuntu1.18.04
2022-08-17 18:06:28 install libgpm2:i386 <none> 1.20.7-5
2022-08-17 18:07:18 install libxau6:i386 <none> 1:1.0.8-1ubuntu1
2022-08-17 18:07:18 install libbsd0:i386 <none> 0.8.7-1ubuntu0.1
2022-08-17 18:07:18 install libxdmcp6:i386 <none> 1:1.1.2-3
2022-08-17 18:07:18 install libxcb1:i386 <none> 1.13-2~ubuntu18.04
2022-08-17 18:07:19 install libx11-6:i386 <none> 2:1.6.4-3ubuntu0.5
2022-08-17 18:07:19 install libxext6:i386 <none> 2:1.3.3-1
2022-08-17 18:07:19 install libxtst6:i386 <none> 2:1.2.3-1
2022-08-17 18:07:40 install libexpat1:i386 <none> 2.2.5-3ubuntu0.7
2022-08-17 18:07:40 install zlib1g:i386 <none> 1:1.2.11.dfsg-0ubuntu2.1
2022-08-17 18:07:40 install libpng16-16:i386 <none> 1.6.34-1ubuntu0.18.04.2
2022-08-17 18:07:40 install libfreetype6:i386 <none> 2.8.1-2ubuntu2.2
2022-08-17 18:07:40 install libfontconfig1:i386 <none> 2.12.6-0ubuntu2
2022-08-17 18:07:40 install libxrender1:i386 <none> 1:0.9.10-1
2022-08-17 18:07:40 install libxft2:i386 <none> 2.3.2-1
2022-08-17 18:08:02 install libstdc++6:i386 <none> 8.4.0-1ubuntu1~18.04
2022-08-18 12:25:05 install m4:amd64 <none> 1.4.18-1
2022-08-18 12:25:05 install flex:amd64 <none> 2.6.4-6
2022-08-18 12:25:06 install libbison-dev:amd64 <none> 2:3.0.4.dfsg-1build1
2022-08-18 12:25:06 install bison:amd64 <none> 2:3.0.4.dfsg-1build1
2022-08-18 12:25:06 install libelf-dev:amd64 <none> 0.170-0.4ubuntu0.1
2022-08-18 12:25:06 install libfl2:amd64 <none> 2.6.4-6
2022-08-18 12:25:06 install libfl-dev:amd64 <none> 2.6.4-6
2022-08-18 13:46:30 install hwdata:all <none> 0.290-1ubuntu0.18.04.1
2022-08-18 13:46:30 install linux-tools-common:all <none> 4.15.0-192.203
2022-08-18 13:46:30 install linux-tools-4.15.0-192:amd64 <none> 4.15.0-192.203
2022-08-18 13:46:30 install linux-tools-4.15.0-192-generic:amd64 <none> 4.15.0-192.203
2022-08-18 13:46:30 install linux-tools-virtual:amd64 <none> 4.15.0.192.177
2022-08-18 13:58:11 install linux-hwe-5.4-tools-common:all <none> 5.4.0-125.141~18.04.1
2022-08-18 13:58:11 install linux-hwe-5.4-tools-5.4.0-77:amd64 <none> 5.4.0-77.86~18.04.1
2022-08-18 13:58:11 install linux-tools-5.4.0-77-generic:amd64 <none> 5.4.0-77.86~18.04.1
Hi Rainwang
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
