Error occurred when build the u-boot
- 4 years ago
it seemed work today.
in fact , i was looking for the solution to support the usb blaster under WSL2, what i did is as below:
1. My platform: WSL2 + ubuntu 18.04 on windows 10
2. to support USB blaster on WSL2, i upgraded the linux kernel from 5.10.16.3 to 5.10.60.1.
3. checked the specification Intel® FPGA Software Installation and Licensing, found some dependencies need to be installed.
from /var/log/dpkg.log, i upgraded below packages, not sure which one is root cause
at last, the usb blaster still can't work on ubuntu, but i found the u-boot now can be made successfully.
2022-08-17 14:57:23 install liblzma-dev:amd64 <none> 5.2.2-1.3ubuntu0.1
2022-08-17 15:27:33 install lib32tinfo5:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:27:33 install lib32ncurses5:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:42:05 install zlib1g-dev:amd64 <none> 1:1.2.11.dfsg-0ubuntu2.1
2022-08-17 15:57:17 install libtinfo-dev:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:57:17 install libncurses5-dev:amd64 <none> 6.1-1ubuntu1.18.04
2022-08-17 15:57:17 install u-boot-tools:amd64 <none> 2020.10+dfsg-1ubuntu0~18.04.2
2022-08-17 15:57:17 install device-tree-compiler:amd64 <none> 1.4.5-3
2022-08-17 15:57:17 install libattr1-dev:amd64 <none> 1:2.4.47-2build1
2022-08-17 15:57:17 install libacl1-dev:amd64 <none> 2.2.52-3build1
2022-08-17 15:57:17 install uuid-dev:amd64 <none> 2.31.1-0.4ubuntu3.7
2022-08-17 16:06:50 install libdouble-conversion1:amd64 <none> 2.0.1-4ubuntu1
2022-08-17 16:06:50 install libqt5core5a:amd64 <none> 5.9.5+dfsg-0ubuntu2.6
2022-08-17 16:06:50 install libqt5dbus5:amd64 <none> 5.9.5+dfsg-0ubuntu2.6
2022-08-17 16:06:50 install libqt5network5:amd64 <none> 5.9.5+dfsg-0ubuntu2.6
2022-08-17 16:06:51 install libqt5qml5:amd64 <none> 5.9.5-0ubuntu1.1
2022-08-17 16:06:51 install qttranslations5-l10n:all <none> 5.9.5-0ubuntu1
2022-08-17 16:10:21 install libc6-dev-i386:amd64 <none> 2.27-3ubuntu1.6
2022-08-17 16:10:21 install libc6-x32:amd64 <none> 2.27-3ubuntu1.6
2022-08-17 16:10:21 install libc6-dev-x32:amd64 <none> 2.27-3ubuntu1.6
2022-08-17 16:10:22 install libx32gcc1:amd64 <none> 1:8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32gomp1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32gomp1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32itm1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32itm1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32atomic1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32atomic1:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32asan4:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32asan4:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install lib32ubsan0:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32stdc++6:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32ubsan0:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install lib32cilkrts5:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32cilkrts5:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install lib32mpx2:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32quadmath0:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install libx32quadmath0:amd64 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 16:10:22 install lib32gcc-7-dev:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install libx32gcc-7-dev:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:22 install gcc-7-multilib:amd64 <none> 7.5.0-3ubuntu1~18.04
2022-08-17 16:10:23 install gcc-multilib:amd64 <none> 4:7.4.0-1ubuntu2.3
2022-08-17 16:32:30 install libpng12-0-udeb:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 16:39:07 install libpng12-0-udeb:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 16:42:55 install zlib1g-udeb:amd64 <none> 1:1.2.8.dfsg-1ubuntu1
2022-08-17 16:47:55 install libpng12-0-udeb:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 16:53:54 install libpng12-0:amd64 <none> 1.2.50-1ubuntu2.14.04.3
2022-08-17 18:05:41 install gcc-8-base:i386 <none> 8.4.0-1ubuntu1~18.04
2022-08-17 18:05:41 install libgcc1:i386 <none> 1:8.4.0-1ubuntu1~18.04
2022-08-17 18:05:41 install libc6:i386 <none> 2.27-3ubuntu1.6
2022-08-17 18:05:41 install libbz2-1.0:i386 <none> 1.0.6-8.1ubuntu0.2
2022-08-17 18:06:28 install libtinfo5:i386 <none> 6.1-1ubuntu1.18.04
2022-08-17 18:06:28 install libncurses5:i386 <none> 6.1-1ubuntu1.18.04
2022-08-17 18:06:28 install libgpm2:i386 <none> 1.20.7-5
2022-08-17 18:07:18 install libxau6:i386 <none> 1:1.0.8-1ubuntu1
2022-08-17 18:07:18 install libbsd0:i386 <none> 0.8.7-1ubuntu0.1
2022-08-17 18:07:18 install libxdmcp6:i386 <none> 1:1.1.2-3
2022-08-17 18:07:18 install libxcb1:i386 <none> 1.13-2~ubuntu18.04
2022-08-17 18:07:19 install libx11-6:i386 <none> 2:1.6.4-3ubuntu0.5
2022-08-17 18:07:19 install libxext6:i386 <none> 2:1.3.3-1
2022-08-17 18:07:19 install libxtst6:i386 <none> 2:1.2.3-1
2022-08-17 18:07:40 install libexpat1:i386 <none> 2.2.5-3ubuntu0.7
2022-08-17 18:07:40 install zlib1g:i386 <none> 1:1.2.11.dfsg-0ubuntu2.1
2022-08-17 18:07:40 install libpng16-16:i386 <none> 1.6.34-1ubuntu0.18.04.2
2022-08-17 18:07:40 install libfreetype6:i386 <none> 2.8.1-2ubuntu2.2
2022-08-17 18:07:40 install libfontconfig1:i386 <none> 2.12.6-0ubuntu2
2022-08-17 18:07:40 install libxrender1:i386 <none> 1:0.9.10-1
2022-08-17 18:07:40 install libxft2:i386 <none> 2.3.2-1
2022-08-17 18:08:02 install libstdc++6:i386 <none> 8.4.0-1ubuntu1~18.04
2022-08-18 12:25:05 install m4:amd64 <none> 1.4.18-1
2022-08-18 12:25:05 install flex:amd64 <none> 2.6.4-6
2022-08-18 12:25:06 install libbison-dev:amd64 <none> 2:3.0.4.dfsg-1build1
2022-08-18 12:25:06 install bison:amd64 <none> 2:3.0.4.dfsg-1build1
2022-08-18 12:25:06 install libelf-dev:amd64 <none> 0.170-0.4ubuntu0.1
2022-08-18 12:25:06 install libfl2:amd64 <none> 2.6.4-6
2022-08-18 12:25:06 install libfl-dev:amd64 <none> 2.6.4-6
2022-08-18 13:46:30 install hwdata:all <none> 0.290-1ubuntu0.18.04.1
2022-08-18 13:46:30 install linux-tools-common:all <none> 4.15.0-192.203
2022-08-18 13:46:30 install linux-tools-4.15.0-192:amd64 <none> 4.15.0-192.203
2022-08-18 13:46:30 install linux-tools-4.15.0-192-generic:amd64 <none> 4.15.0-192.203
2022-08-18 13:46:30 install linux-tools-virtual:amd64 <none> 4.15.0.192.177
2022-08-18 13:58:11 install linux-hwe-5.4-tools-common:all <none> 5.4.0-125.141~18.04.1
2022-08-18 13:58:11 install linux-hwe-5.4-tools-5.4.0-77:amd64 <none> 5.4.0-77.86~18.04.1
2022-08-18 13:58:11 install linux-tools-5.4.0-77-generic:amd64 <none> 5.4.0-77.86~18.04.1
Hi Rainwang
Could you try changing the steps for building the uboot to this:
tar xf gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
rm gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH
# Generate U-Boot device tree
cd $SOCEDS_DEST_ROOT/examples/hardware/a10_soc_devkit_ghrd/
rm -rf software/bootloader
mkdir -p software/bootloader
cd software/bootloader
# Get the U-Boot sourece code
git clone https://github.com/altera-opensource/u-boot-socfpga
cd u-boot-socfpga
git checkout -b test -t origin/socfpga_v2020.04
# Generate DTS include file based on the handoff file
./arch/arm/mach-socfpga/qts-filter-a10.sh \
../../../hps_isw_handoff/hps.xml \
arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.h
# Build U-Boot
export CROSS_COMPILE=arm-none-linux-gnueabihf-
make socfpga_arria10_defconfig
make -j 24
Jingyang, Teh
- Rainwang4 years ago
Contributor
hi, jingyang,
I tested the steps on my laptop, and below are my feedback.
1. when i excecute the 1 step:
error message showed that the certificate issue. so i work around it by downloading the package on windows10 and then put it into a folder.
$ wget https://developer.arm.com/-/media/Files/downloads/gnu/11.2-2022.02/binrel/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
--2022-08-17 09:59:39-- https://developer.arm.com/-/media/Files/downloads/gnu/11.2-2022.02/binrel/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz
Connecting to XXXXXXXX :88... connected.
ERROR: cannot verify developer.arm.com's certificate, issued by ‘C=US,ST=CT,L=Fairfield,OU=GE Corporate IT,O=General Electric Company,CN=GE External Issuing CA 202208162100’:
Unable to locally verify the issuer's authority.
To connect to developer.arm.com insecurely, use `--no-check-certificate'.------------------------------------------------------------
2. on the SOPC command shell, i extract the package and also excecuted the rest steps, most run smooth except the make command.
below are the screen i copied. there are some chinese in the log which may caused by my OS version, but it is unimportant because these steps are excecuted successfully.
so still need you help to check the problem, thank you in advance.
305019592@GB1LL2J3E /cygdrive/c/users/305019592/downloads
$ tar xf gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.xz305019592@GB1LL2J3E /cygdrive/c/users/305019592/downloads
$ export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH305019592@GB1LL2J3E /cygdrive/c/users/305019592/downloads
$ cd $SOCEDS_DEST_ROOT/examples/hardware/a10_soc_devkit_ghrd/305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd
$ rm -rf software/bootloader305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd
$ mkdir -p software/bootloader305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd
$ cd software/bootloader305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd/software/bootloader
$ git clone https://github.com/altera-opensource/u-boot-socfpga
正克隆到 'u-boot-socfpga'...
remote: Enumerating objects: 860053, done.
remote: Counting objects: 100% (58103/58103), done.
remote: Compressing objects: 100% (11431/11431), done.
remote: Total 860053 (delta 46220), reused 58095 (delta 46217), pack-reused 801950
接收对象中: 100% (860053/860053), 206.09 MiB | 237.00 KiB/s, 完成.
处理 delta 中: 100% (706474/706474), 完成.
正在更新文件: 100% (17968/17968), 完成.305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd/software/bootloader
$ cd u-boot-socfpga305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd/software/bootloader/u-boot-socfpga
$ git checkout -b test -t origin/socfpga_v2020.04
正在更新文件: 100% (13189/13189), 完成.
分支 'test' 设置为跟踪 'origin/socfpga_v2020.04'。
切换到一个新分支 'test'305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd/software/bootloader/u-boot-socfpga
$ ./arch/arm/mach-socfpga/qts-filter-a10.sh \
> arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.h305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd/software/bootloader/u-boot-socfpga
$ export CROSS_COMPILE=arm-none-linux-gnueabihf-305019592@GB1LL2J3E /cygdrive/c/intelFPGA_pro/20.1/embedded/examples/hardware/a10_soc_devkit_ghrd/software/bootloader/u-boot-socfpga
$ make socfpga_arria10_defconfig
makefile:37: *** missing separator. Stop.
