Chloé_Russell
7 years agoEPCQL controller I Quartus version 16.0
Hello, I am trying to access in read and write my EPCQL-1024 from simple soft running in NIOSII. I have the Altera Serial Flash Controller I configured in QUAD mode connected from its avl_csr and a...
YuanLi_S_Intel
7 years agoHi Chloe,
JTAG is the bridge to enable communication between Host PC and FPGA. Correct frequency is needed in order to establish a clean and correct timing waveform for JTAG signals. This is probably the reason that you don’t see any effect after you have performed write operation / erase operation. Once you have re-powered the board, the communication will become normal and you are able to see the action that you have done previously (erase sector or write specific data to specific address).
Thank You.
YL
Chloé_Russell
7 years agoHi,
I’ve posted a question about FD support, I did not get any reply and I’m confused a little bit using the drivers (I do not know when to use functions with File Descriptor support, does using file descriptor support need to work with Linux?). Your reply will be much appreciated.
Here is my question :
This is my first use of Software drivers. I'm working with the Quartus standard version 16.0.
when I used the "altera_avalon_uart_write" and "altera_avalon_uart_read" functions, things go right.. but when trying to use FD (altera_avalon_uart_write_fd and altera_avalon_uart_read_fd) , the parameter SP points to a false base address although the file has been correctly opened, it returns a valid value (!=NULL).
my code is :
int main()
altera_avalon_uart_state* sp_UART_0;
altera_avalon_uart_state* sp_UART_1;
sp_UART_0->base = UART_0_BASE;
sp_UART_1->base = UART_1_BASE;
char tx_buffer[8] = "BITBANG";
char rx_buffer[8];
alt_fd* fp_uart_1;
alt_fd* fp_uart_0;
fp_uart_1= open ("/dev/uart_1", O_RDWR); //Open file for reading and writing
fp_uart_0= open ("/dev/uart_0",O_RDWR); //Open file for reading and writing
printf("call init uart\n");
altera_avalon_uart_init(sp_UART_1, UART_1_IRQ_INTERRUPT_CONTROLLER_ID,UART_1_IRQ);
altera_avalon_uart_init(sp_UART_0, UART_0_IRQ_INTERRUPT_CONTROLLER_ID,UART_0_IRQ);
int wr = altera_avalon_uart_write_fd (fp_uart_1,tx_buffer,sizeof(tx_buffer)) ;
printf("wr = %d\n",wr);
alt_busy_sleep(1000000); / delay 1us /// 1 s
int rd = altera_avalon_uart_read_fd (fp_uart_0,rx_buffer,sizeof(tx_buffer)) ;
printf(" rd = %d\n",rd);
printf("rx_buffer = '%s'\n\n",rx_buffer);
printf("sp_UART_0 base = 0x%08X \n", sp_UART_0->base);
printf("sp_UART_0 ctrl = 0x%08X \n", sp_UART_0->ctrl);
printf("sp_UART_0 tx_buf = '%s' \n", sp_UART_0->tx_buf);
printf("sp_UART_0 rx_buf = '%s' \n\n\n", sp_UART_0->rx_buf);
printf("sp_UART_1 base = 0x%08X \n", sp_UART_1->base);
printf("sp_UART_1 ctrl = 0x%08X \n", sp_UART_1->ctrl);
printf("sp_UART_1 tx_buf = '%s' \n", sp_UART_1->tx_buf);
printf("sp_UART_1 rx_buf = '%s' \n\n", sp_UART_1->rx_buf);
printf(" rx_buffer = %s\n",rx_buffer);
altera_avalon_uart_close (fp_uart_1) ;
altera_avalon_uart_close (fp_uart_0) ;
free(fp_uart_1);
free(fp_uart_0);
return 0;
CR
