Chloé_Russell
7 years agoEPCQL controller I Quartus version 16.0
Hello, I am trying to access in read and write my EPCQL-1024 from simple soft running in NIOSII. I have the Altera Serial Flash Controller I configured in QUAD mode connected from its avl_csr and a...
YuanLi_S_Intel
7 years agoHi Chloe Russel,
Can you check if your write command is using QUAD mode? Also, are you using USB Blaster II to connect your FPGA with Host PC? If it so, can you change the TCK frequency to 6MHz?
YL
