ETang2
4 years agoDE10-Standard : Accessing HPS I2C bus from outside
Hello, i would like to connect an external I2C sensor to the HPS I2C bus to access it from HPS. I look carefully the DE10-Standard documentation about this but i'm a little confused. I think i can co...
- 4 years ago
Hi Eric,
I am not sure which pins you are referring to, but yes you can connect and access them from HPS, but you need to connect to the right pins, please check your schematic diagram which has the I2C pins available.
Also, you need to make sure the I2C pins are "routed to HPS" in Platform Designer.
ETang2
4 years agoHi and thanks.
Eric
