De10 HPS issue with FPGA interval timer IP
I'm now using the interval timer ip on HPS, I set the ip as general purposed timer.
The timer is set to 100 ms and there is a timer_palus link to my fpga led[1]
The setting is as shown:
And it was linked to fpga only AXI bridge and Avalon mm bridge.
I called the timer as shown using C:
Then I charged the timer by following orders:
*(Timer+1) = 0b1010 //Stop-1 Start-0 count -1 ITO-0
*(TImer+2) = 0x10& 0xFFFF;
*(Timer+3) = (0x10>>16)& 0xFFFF;
*(Timer+ 1) = 0b0110; //Stop-0 Start -1 count -1 ITO - 0
That should start the timer.
And I set a while loop to wait for the LED[1] to bilink for it is linked to the timeout export.
But nothing happend.
And when I want to read the *(Timer) status the TO bit is always 1 even if I set it to 0.
So my questions are:
1. What happened? Why the timer status of TO is always 1?
2.Why the led[1] didn't blink?
3. What should I do to fix it?
4. By setting the period register, ex. = 10, is that mean the timer was set to 10*100 ms?In another word, if the timer is fixed period, is that mean timer is set to 100 ms?
In case my top level file is wrong I attached my top level file, there is only one line related to the timer:
assign LEDR[1]=timer_export or something.
reguards.
- tehjingy_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
