ramsoffer_123
4 years agoddr3 megawizard on cyclone V device
Hey everyone,
Im trying to implement the DDR3 example from the megawizard in quartus 14.1 version.
Im using the Cyclone V Soc development Suite.
in the generation section Im getting those error...
AdzimZM_Altera
4 years agoHi Ram,
Thank you for submitting your question in Intel Community.
I'm Adzim from Penang Global Application Engineer will assist you in this thread.
I've tried to generate the example design in Quartus v14.1 and the generating process is successfully. I will attach the snapshot.
I may not use the exact IP parameter setting as your setup.
It's great if you can share the IP parameter setting for issue replication purpose.
Adzim
- AdzimZM_Altera4 years ago
