Cyclone V SoC freeRTOS DS-5 ERROR(CMD360) when trying to program
It seems that the project may not have been setup correctly, have you tried running the simple demo in the link?
Did the simple demo works? Have you run any RTOS on any devices before?
The simple demo did not work. It is not able to start the target with u-boot-spl image and fails due to timeout.
I have not set up RTOS on any device before. Any clues as to how to overcome this step would be much appreciated.
- EBERLAZARE_I_Intel5 years ago
For better understanding of the Cyclone V SoC, you may want to check out its HPS TRM doc and our Rocketboards document on how the U-boot and preloader is generated.
I believe you do not have these files in your "pwd" current working directory which is the original U-boot files which is why your execution was not able to execute. You can see your errors reported missing file. You may check in the Rocketboards on how you git fetch U-boot and have all the files ready.
https://rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
https://www.intel.com/content/www/us/en/programmable/documentation/sfo1410143707420.html
