BrianSune_Froum's avatar
BrianSune_Froum
1 year ago
Custom board on Cyclone V HPS SDRAM preloader test
Dear Intel and all,
Apart from the DDR3 topology.
The first stage testing shows a very puzzling behavior.
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 50000 KHz
CLOCK: EOSC2 clock 50000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 600 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 488 KHz
CLOCK: QSPI clock 2343 KHz
RESET: COLD
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
SDRAM: Ensuring specified SDRAM size is correct ...failed
  • The final result is that even with a fly-by routed topology there are no issue on both 1.5V and 1.35V DDR3 DDR3L.
    The MT41K128M16 /w 1k page size shows no sanity issue on memtest stresapptest on distro.
    UBOOT memory normal test also passed w/o any errors.
    So after short testing we can only assume there are inherent bug on Quartus 18.1? or HPS IP.
    No matter it is /w or /wo the board settings no drop no crash no stuck.
    So the case ends here.
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    Jingyang, Teh
