could not create the verilog HDL file
Were you able to create a Quartus project for the Cyclone V GX chip? Do you get this error when running the Quartus flow ?
The error states that the design file you created has illegal characters. Can you post the code here so that we can check it.?
Are you creating the design using the Block diagram edit BDF file. If so, delete the existing .v files, and then try compiling again. You could also try a clean of the project via the Project menu -> Clean Project.
Hai Abe
Thank you for your reply as per your instruction tried the points what you tell in previous msg but the thinks are getting again error
I created the design using the Block diagram edit BDF file and also deleted the existing .v file and tried once again also but the same error is appering as well as cleared my project via project menu-> clean project same error is appering on the screen
for more information i have provided screenshots in below plz go through my snaps
let me know the solutions
Thanks ,
Aravind p
