anrfpga
4 years agoContents of hps debug sof file
Hi All,
I am following this link to build a bootloader for bare metal application and trying to understand some of the steps involved.
What are the contents of the ghrd_agfb014r24b2e2...
aikeu
4 years agoHi anrfpga,
I cant be sure about the size different considering both sof files.
I think use the GHRD sof file will be better if you wanto check those basic hardware configuration as the default U-boot is built considering the GHRD provided.
Try to check out the status in the debugging mode and verify any status which change during run time. It will be better if you have idea of what you going to debug.
AiK Eu
