MUpam's avatar
MUpam
2 years ago
Compilation issue
I want to do some calculations which involves floating point with nios ii. So I made qsys system adding floating point hardware 2 component then generated hdl. and add all files to quartus and tried to compile but I got this error.
I search for error and it says repeated file give this error but there is no any file named with my top file. Anyone could you please help me.
Thanks in advance  
  • Hi,
    Firstly, remove the/all unnecessary files in the "Files" tab in Quartus after you generate HDL in Platform Designer.
    Then locate the .qip files in the "synthesis" folder directory that you generated from Platform Designer above.
    Add the .qip file in the "Files" tab. And compile your Quartus.
  • Hi,
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
