MUpam
3 years agoCompilation issue
I want to do some calculations which involves floating point with nios ii. So I made qsys system adding floating point hardware 2 component then generated hdl. and add all files to quartus and tried ...
- 3 years ago
Firstly, remove the/all unnecessary files in the "Files" tab in Quartus after you generate HDL in Platform Designer.
Then locate the .qip files in the "synthesis" folder directory that you generated from Platform Designer above.
Add the .qip file in the "Files" tab. And compile your Quartus.
EBERLAZARE_I_Intel
3 years agoHi,
Which Quartus version are you working on is it Lite or Standard? Let me re-check the sizes.
"For the top level of your FPGA-based design might be your Platform Designer system (.qsys). However, the FPGA can include additional design logic."
