MUpam
3 years agoCompilation issue
I want to do some calculations which involves floating point with nios ii. So I made qsys system adding floating point hardware 2 component then generated hdl. and add all files to quartus and tried ...
- 3 years ago
Firstly, remove the/all unnecessary files in the "Files" tab in Quartus after you generate HDL in Platform Designer.
Then locate the .qip files in the "synthesis" folder directory that you generated from Platform Designer above.
Add the .qip file in the "Files" tab. And compile your Quartus.
EBERLAZARE_I_Intel
3 years agoHi,
Thanks for the files, I will test it from my side and let you know the results, this might take a few days, I am bit tight up on my side.
Thanks again for your patience.
- MUpam3 years ago
Thank you very much EBERLAZARE_I_In
tel. I’m looking forward to hear from you.
