command not found when build the u-boot
- 4 years ago
after I re-install the linaro tool chain, the issue was fixed. so i believe the root cause is something wrong during linaro tool chain installation.
thank you!
Hi Rainwang
If you happen to met the same error in the future.
I would suggest you trying to set the environmental variable below to point to the cross compiler paths:
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH
export CROSS_COMPILE=arm-none-linux-gnueabihf-
Since there are no feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, someone will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
- Rainwang4 years ago
Contributor
yes, please close this case, thank you for the support!
