DavidGG
1 year agoCannot generate an RSU image with encrypted source code for Agilex7
Hello, I have delivered an encrypted IP to my customer using Altera ampcrypt6 and amplic6 tools using the following command lines: ./amplic6.exe -3 -c -sp 7 -o license_tc5550_3.txt -h any -v 2025.0...
- 1 year ago
I think we can close this ticket now.
Apparently the customer has been able to solve this issue.
But I have not explanation how he solved it (I am not indirect contact with the integrator, there is the end customer in the middle).
In case the issue reproduces I will aks the integrator to open a support ticket by himself.
Thanks and best regards,
David
tehjingy_Altera
1 year agoHi
From the error log, this could be fix if you could generate it without the use of an evaluation license.
Jingyang, Teh
