PeterTs
5 years agoBare-metal application on SDRAM failing to run on DE10-nano
I'm struggling (huge understatement) to get my bare-metal application running and would appreciate some help.
My set up is:
I'm using a DE10-nano development board and have 4 copies of the prelo...
AnilErinch_A_Intel
5 years agoHi Peter,
If the question about MMU still exists , you can check that whether MMU is enabled or not by checking the appropriate register.
You can also verify the MMU status from the logs which you will get while booing the board in the terminal.
Thanks and Regards
Anil
