JET60200
Contributor
6 years agoArria10 SOCFPGA ARM DMA usage - way to use ARM DMA to copy bulk data inside DDR ?
I am using A10 SOCFPGA , where Linux runs on SOC ARM(dual-A9). In my application, there‘re bulks of memory copying from one place to another place each 1ms,currently I use memcpy() which occupy ...
EBERLAZARE_I_Intel
6 years agoHi,
You may find design example in our design store, unfortunately there is no exact design example that you are requesting.
https://fpgacloud.intel.com/devstore/platform/?search=dma&acds_version=any&family=arria-10
However, there is a Data Mover which utilize the msGDMA, that uses the ARM Cortex A9, you may check it out here:
