Arria10 DDR ECC Initialization
Do you have any additional questions?
Hi -
I would like to know what the bit referenced in the reference manual is referring to ? It is in a comment that refers to the whole register.
From my testing I do need to explicitly initialize all of DDR to avoid seeing EEC errors when I first access a location.
Paul
- EBERLAZARE_I_Intel6 years ago
Hi Paul,
I apologize for missing out your initial question "Which "bit" is this referring to. There is no description of any initialization operation in either of these registers."
The "bit" mentioned in ECCCTRL1, is register 0xFFCFB100
while, the "bit" mentioned in ECCCTRL2, is register 0xFFCFB104
Are you configuring the HPS external memory interface (EMIF) to be 16 bits wide with error checking and correction (ECC) enabled? If so, please refer our Intel® Arria® 10 SX Device Errata and Design Recommendations below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/es/es-1053.pdf#page=9
Regards.
- PHJ6 years ago
Thanks for the quick response. We are using DDR in 16-bit mode with ECC enabled and had seen this errata. We are not seeing adverse system performance in this mode, but would be interested to know more details on this - esp what the "sometimes" from the errata text really means, and how doing all DDR accesses via a copyback cache affects the errata condition.
Hi Paul,
I could not find any hard details.
Based on my knowledge, in HPS x16 bit interface with auto-correction enabled, the write performance degrades because there is one extra write-to-read AND read-to-write turnaround time for every write. The degradation will be significant.
I would recommend that you used other mode(x40) if you need the auto-correction feature, if you face the degradation in you system perfomance.
Best Regards.
