arria v ds-5 arm compiler inline assembly
- 3 years ago
compiler v7 can have the single line syntax like below-
__asm("[;]");
__asm{[;]}
for reading CNTFREQ, assign global variable with volatile.
And try to run again,
volatile unsigned int freq=0;
void printReg()
__asm
mrc p15, 0, freq, c14, c0, 0
printf("freq=0x%X", freq);
let me know if you have any query on this.
Jeetesh
Its seems error in the syntax used-
remove the one closing ) from the syntax.
Tiwari
- bsp_user3 years ago
I apologies, I wrote it here wrong.
I encountered two issues:
1. I tried to use "regular" syntax which I saw in other places as well and it didn't work.
(1.png)
I don't know what is wrong with this syntax.
2. I tried another syntax (2.png). now the code compiles but I have two problems:
- There is no volatile statement
- When I execute this asm code via debugger it halts when it reaches the asm code and that's it (I don't see the print value and can't continue to next step or running the debugger)
Thank you
