Arria 10 HPS I2C (designware) issue?
Hello community,
I have a problem with i2c on arria 10 hps. After some time the I2C communication stops and the most curious thing is that it stops with bus free conditions. E.g. SDA and SCL are high. The problem is only with one of the slaves on the big network. The slave is Microchip PIC micro MCU. But before blaming PICmicro I want to be sure that Arria i2c works fine. For me it is not normal the bus to be free and no attempts for slaves access to be present from master side.
The CPUs are not blocked and the system is running
Info: Linux 4.9.76.
Not always but sometimes information like this is yelled on the terminal:
[ 360.815901] INFO: task kworker/0:2:914 blocked for more than 120 seconds.
[ 360.822663] Not tainted 4.9.76-rt61-ltsi-rt-csc5-AUTOINC+413d2d0a9b #1
[ 360.829680] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 360.837476] kworker/0:2 D 0 914 2 0x00000000
[ 360.842968] Workqueue: events set_brightness_delayed
[ 360.847942] [<8079b778>] (__schedule) from [<8079ba74>] (schedule+0x60/0xfc)
[ 360.854972] [<8079ba74>] (schedule) from [<8079ceb0>] (__rt_mutex_slowlock+0x88/0x15c)
[ 360.862862] [<8079ceb0>] (__rt_mutex_slowlock) from [<8079d4ac>] (rt_mutex_slowlock_locked+0xd8/0x260)
[ 360.872135] [<8079d4ac>] (rt_mutex_slowlock_locked) from [<8079d69c>] (rt_mutex_slowlock.constprop.8+0x68/0xa0)
[ 360.882185] [<8079d69c>] (rt_mutex_slowlock.constprop.8) from [<8079d9c8>] (rt_mutex_lock_state+0x9c/0xc4)
[ 360.891803] [<8079d9c8>] (rt_mutex_lock_state) from [<8079da0c>] (rt_mutex_lock+0x1c/0x20)
[ 360.900037] [<8079da0c>] (rt_mutex_lock) from [<8079f764>] (_mutex_lock+0x18/0x1c)
[ 360.907588] [<8079f764>] (_mutex_lock) from [<80540ae4>] (ccuss_smbus_request+0x20/0x24)
[ 360.915675] [<80540ae4>] (ccuss_smbus_request) from [<804a30d8>] (__ccuss_gpio_set+0x38/0x84)
[ 360.924184] [<804a30d8>] (__ccuss_gpio_set) from [<804a3374>] (ccuss_gpio_set+0x50/0x5c)
[ 360.932259] [<804a3374>] (ccuss_gpio_set) from [<8049cfe4>] (_gpiod_set_raw_value+0x70/0x160)
[ 360.940762] [<8049cfe4>] (_gpiod_set_raw_value) from [<8049e380>] (gpiod_set_value_cansleep+0x58/0xa0)
[ 360.950045] [<8049e380>] (gpiod_set_value_cansleep) from [<8062c340>] (gpio_led_set+0x64/0x68)
[ 360.958632] [<8062c340>] (gpio_led_set) from [<8062c3ac>] (gpio_led_set_blocking+0x18/0x20)
[ 360.966960] [<8062c3ac>] (gpio_led_set_blocking) from [<8062aecc>] (set_brightness_delayed+0x80/0xc4)
[ 360.976153] [<8062aecc>] (set_brightness_delayed) from [<8013d444>] (process_one_work+0x1f8/0x570)
[ 360.985083] [<8013d444>] (process_one_work) from [<8013e118>] (worker_thread+0x68/0x614)
[ 360.993149] [<8013e118>] (worker_thread) from [<80143718>] (kthread+0x118/0x120)
[ 361.000525] [<80143718>] (kthread) from [<80108218>] (ret_from_fork+0x14/0x3c)
[ 361.007744] INFO: task cat:29294 blocked for more than 120 seconds.
[ 361.014108] Not tainted 4.9.76-rt61-ltsi-rt-csc5-AUTOINC+413d2d0a9b #1
[ 361.021131] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 361.028928] cat D 0 29294 1982 0x00000000
[ 361.034433] [<8079b778>] (__schedule) from [<8079ba74>] (schedule+0x60/0xfc)
[ 361.041465] [<8079ba74>] (schedule) from [<8079de7c>] (schedule_timeout+0x90/0x34c)
[ 361.049098] [<8079de7c>] (schedule_timeout) from [<8018b3e4>] (msleep+0x3c/0x48)
[ 361.056478] [<8018b3e4>] (msleep) from [<80540be8>] (ccuss_smbus_read_word_data+0x3c/0x4c)
[ 361.064727] [<80540be8>] (ccuss_smbus_read_word_data) from [<8064a848>] (ccuss_iio_read_raw+0x40/0x7c)
[ 361.074003] [<8064a848>] (ccuss_iio_read_raw) from [<80646e70>] (iio_read_channel_info+0x98/0x9c)
[ 361.082854] [<80646e70>] (iio_read_channel_info) from [<80518750>] (dev_attr_show+0x2c/0x58)
[ 361.091266] [<80518750>] (dev_attr_show) from [<802c19cc>] (sysfs_kf_seq_show+0x98/0x100)
[ 361.099420] [<802c19cc>] (sysfs_kf_seq_show) from [<802c02b8>] (kernfs_seq_show+0x34/0x38)
[ 361.107665] [<802c02b8>] (kernfs_seq_show) from [<802767b8>] (seq_read+0xbc/0x4ec)
[ 361.115855] [<802767b8>] (seq_read) from [<802c1118>] (kernfs_fop_read+0x148/0x1dc)
[ 361.123791] [<802c1118>] (kernfs_fop_read) from [<80250150>] (do_readv_writev+0x310/0x3e0)
[ 361.132035] [<80250150>] (do_readv_writev) from [<80250270>] (vfs_readv+0x50/0x68)
[ 361.139580] [<80250270>] (vfs_readv) from [<80283034>] (default_file_splice_read+0x180/0x294)
[ 361.148077] [<80283034>] (default_file_splice_read) from [<80282b84>] (do_splice_to+0x8c/0xa0)
[ 361.156658] [<80282b84>] (do_splice_to) from [<80282c4c>] (splice_direct_to_actor+0xb4/0x25c)
[ 361.165154] [<80282c4c>] (splice_direct_to_actor) from [<80282e8c>] (do_splice_direct+0x98/0xc0)
[ 361.173909] [<80282e8c>] (do_splice_direct) from [<80250754>] (do_sendfile+0x1b4/0x334)
[ 361.181887] [<80250754>] (do_sendfile) from [<802512f0>] (SyS_sendfile64+0x11c/0x148)
[ 361.189694] [<802512f0>] (SyS_sendfile64) from [<80108140>] (ret_fast_syscall+0x0/0x50)
And after some debugging the issue appears only when STOP_DET and TX_ABORT interrupt appear simultaniously.
Any suggestions?
1 Reply
- EBERLAZARE_I_Intel
I suggest you to look thoroughly the Intel FPGA Avalon I2C (Master) Core document, Chapter 15 page 164.
Best Regards.
