Any Cyclone V soc bare metal startup project settings available?
Hi CAlex,
I do not have the similar .ds file in my folder directory of my baremetal application from the error you have shown.
I think the .ds script it trying to run but encounter error based on what is written in the script.
I would like to test it out with Arm ds. I will find a time to test on the board with arm ds next week.
At the mean time if used back the timer baremetal example in arm-ds, will it work?
Aik Eu
- CAlex3 years ago
Contributor
I cant even load the spl, it means it cant start at DDR. Once I could but now I cant witht the same steps.
The ds file is form the cycloneV soc hwlib example from rocketboards.org
If you succeeded by windows, could you please share the GHRD software folder?
My environemnt is :
SOCEDS standard 20.1ARM DS 21.1 evaluation
Quartus 22.1lite
WSL2 ubuntu 20.04 LTS
- CAlex3 years ago
Contributor
I solved it, I used the older version U-boot(like the example said 2020.04 would work).
The newest version 2023.0~2022.10 cant work under my environment though.
You guys may want to test and fix this maybe?
Reguards
