Any Cyclone V soc bare metal startup project settings available?
Hi CAlex,
If you wanto run from ddr you will need the SPL(u-boot-splx4.sfp) to init the ddr first.
To boot from ddr you will need to run the below cmd when makding your application code:
Refer to the section(Software Examples) with the table https://github.com/altera-opensource/intel-socfpga-hwlib
if ddr the cmd will be:
make SEMIHOSTED=0 MEMORY=ddr
Aik Eu
Yes I downloaded/ran the u-boot-spl and .bin file to _bss_end. And the console said it was succeed,
After that I
1. disconnect the preloader ds debug(connect only),i didn't find u-boot-splx4.sfp on my u-boot-socfpga/spl/ file, could you please tell me where to find it?
2. connect the program debug(start from entry point) with the scatter file cvav-ddr.scat (and built/link the interrupt_armcc.s) entrypoint is 0x0100_0000 with the Vector
I have the other debug started from 0x0200_0000 without Vector
3. Then the error showed up.
Reguards.
