Any Cyclone V soc bare metal startup project settings available?
Hi CAlex,
Are you mentioned the part where you are trying to build the u-boot?
After you have obtained and built your ghrd, you will proceed to the next step to consider consider u-boot
Referring to this document on the part where you are going to build u-boot:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
Note that you will need the embedded_command_shell.sh to perform the build.
Aik Eu
Yes I build the u-boot , more accurate, the u-boot-spl from my GHRD.
Since I'm working on bare metal, I don't need u-boot.
As for preloader.ds part, it is from the GHRD itself.
The Linaro keep failing so I start to use ARMCC
Another wield issue occurred:
when mainully load the spl ,downloaded the axf file and start from the entry point,
it started at S:FFFF0000 where is the on chip RAM location.
But in the guide it should start at S:02000000 where the SDRAM at.
When I used the scatter pointed to 0x02000000, the program made an error from 0xFFFF0000.
So my question is how can I start from sdram?
Here is the reference PDF I followed:
BARE METAL USER GUIDE from your download center.
