MCOUNSELL
7 years agoalt_qspi_read() QSPI addressing problem
alt_qspi_read() is returning data from the QSPI address -1. I've written data to the QSPI by two different methods. quartus_hps.exe and also using alt_qspi_write function it in both cases the data ...
EBERLAZARE_I_Intel
7 years agoHi,
Did you run into any error when writing the data via quartus_hps.exe?
MCOUNSELL
7 years agoHi,
No, writing via quartus_hps.exe is perfect. Never seen any errors and I have written many many times using this exe.
Mike
- EBERLAZARE_I_Intel7 years ago
I assume if there was no error when booting up the board such as bad u-boot.img etc or anything that prevented the board from booting, everything should be fine.
