raju1421
3 years ago[Agilex]: Programming & Flashing FPGA File (.jic) to QSPI Flash from HPS through ethernet
Hi all, I have been using the below mentioned guide for porting u-boot and linux on agilex board Building Bootloader for Agilex 7 | Documentation | RocketBoards.org But, there is no information ab...
tehjingy_Altera
3 years agoHi Raju
Did you gone through the link I sent you?
With RSU, you could send the bitstream through the ethernet and with the RSU application on the board you could do the FPGA Programming.
Jingyang, Teh
raju1421
3 years agoHi,
Thanks for the response.
We are working on it, once the required results come, i will let you know.
Thanks & Regards
Raju S
