MesbahKarim
3 years agoAgilex Ftile is not asserting tx_ready after the reset sequence (tx_rreset/tx_reset_ack)
I build my controller model to Agilex F-tile transceiver. Please see the configuration below for F-tile and simulation waveform. Xcvr is asserting tx_reset/tx_reset_ack and rx_reset/rx_r...
Kshitij_Intel
3 years agoHi,
Can you please check are you fulfilling the reset signal requirements? Please refer below link.
Also, tx_reset and rx_reset input for TX/RX PMAs and TX/RX datapath. Must be kept asserted until tx_reset_ack and rx_reset_ack is asserted. Applies to all TX/RX channels in a F-Tile PMA/FEC Direct PHY Intel® FPGA IP instance.
Can you please clarify which Run-Time Reset Sequence you are following.
- 3.8.6. Run-time Reset Sequence—TX
- 3.8.7. Run-time Reset Sequence—RX
- 3.8.8. Run-time Reset Sequence—TX + RX
- 3.8.9. Run-time Reset Sequence—TX with FEC
Thank you
Kshitij Goel
