Agilex 7 dk_si_agi027fa FPGA issue
I want to simplify the issue:
First, we followed the GSRD user guide instructions:
- We made sure we follow it precisely - we went over it 4-5 times.
- Linux boots properly, we have ssh access, and we have serial access (with minicom).
- We can run the sample scripts and we can use the ssh GUI (even though they don't provide the expected LED outputs).
The first part that fails is "Running Sample Applications". "Hello World" works, but the fpga related samples don't work - toggling leds from the sample scripts, and toggling leds from the ssh.
(the http gui opens properly, but providing some input - like to toggle every 100ms - doesn't show any result).
My first post shows some solutions I tried and outputs to commands that should work, according to what I saw in the web, and it seems that fpga wasn't configured correctly.
Is there anything we can try, or is there some way to know at what part we are failing? What can be the next step of investigation?
Assitance will be much appreciated.
Thank you.
