9 years agoZero extender and zero checker
1) How can extend an output with zeros in Quartus ii (Schematic / Block)? 2) How can I make a flag named 'zero' to check if an output is zero? Thank you!4 Replies
1. Use named association - tie unused bits to ground
2. NOR all of the bits. - Altera_Forum
--- Quote Start --- 1. Use named association - tie unused bits to ground 2. NOR all of the bits. --- Quote End --- Than you so much but, can you explain more about it? I'm totally a beginner ... - Altera_Forum
1. Practice using the graphical designer - this is a very basic operation
2. Google it.. - Altera_Forum
I got the second but, the first I did not find it, Can you specify the name and the place where I can find it more? And another Q please, how can I negate a 32-bit input? Thanks again.
