I appreciate you taking the time to try to model the behavior pletz. I'm pasting the code here, so we can discuss easier.
module BPUFelement(
excite,
clk,
out
input excite;
input clk;
output out;
wire net1, net2;
preset_latch latch_i1 (.clk(clk),.D(net2),.pre(excite),.Q(net1));
reset_latch latch_i2 (.clk(clk),.D(net1),.clr(excite),.Q(net2));
assign out = net2;
endmodule
module preset_latch (pre,D,Q,clk);
input pre,D,clk;
output Q;
reg reg_int;
always@(pre or D or clk) begin
if (clk)
begin
if(pre)
reg_int <= 1;
end
else reg_int <= D ;
end
assign Q = reg_int;
endmodule
module reset_latch (clk,D,Q,clr);
input clr,D,clk;
output Q;
reg reg_int;
always@(clr or D or clk) begin
if (clk)
begin
if(clr)
reg_int <= 0;
end
else reg_int <= D ;
end
assign Q = reg_int;
endmodule
According to the description in the paper, it seems to me that the circuit follows these rules:
Excite = 1, then drops to 0
CLK = 1, always
if CLK = 1, then Q = D
if PRE = 1, then Q = 1
if CLR = 1, then Q = 0
seems from the code above that only if CLK = 0, then Q = D? Wouldn't it be more accurate to say:
if (clk)
begin
if(clr) reg_int <= 0;
else reg_int <= D ;
end
end
If I make that change to the preset_latch and reset_latch modules, and run a simulation, I get the following result:
http://img262.imageshack.us/img262/9418/simres1qu3.th.jpg (
http://img262.imageshack.us/my.php?image=simres1qu3.jpg)
http://img262.imageshack.us/images/thpix.gif (
http://g.imageshack.us/thpix.php)
and zoomed in:
http://img262.imageshack.us/img262/337/simres2wc0.th.jpg (
http://img262.imageshack.us/my.php?image=simres2wc0.jpg)
it seems that the circuit is stabilizing on a particular value, which here happens to be 1. I haven't tried this on a real board yet, but I will later today.
