14 years ago --- Quote Start --- The problem is that the files are larger than 1024 kb. --- Quote End --- No they aren't. Just a few kB each. I don't want to start a general discussion about the pros and cons of translaters like X-HDL. I once tested it and found it producing reasonable code quality. But I'm not presently using it. You shouldn't translate a MegaWizard generated file like spipll.c. Instead, you should be able to regenerate it as VHDL file in the MegaWizard.
