JoeLUH
3 years agoWrong syntax highlighting in editor when using "define" in Verilog
Hi
Switching from Quartus Prime Standard 19 to >=20 I found out that the syntax highlighting is not working correctly any more in the editor if a definition statement is given in a different file. ...
- 3 years ago
Thank you for the feedback provided on this issue.
The engineering team has aware of this issue and they will plan to fix this. (usually will takes some time e.g. a couple of months before it got fix in the next Quartus release.)
Since this issue will be planned to be fixed, do you need further help in this case?
Richard Tan
RichardT_altera
3 years agoJust to inform you that the engineering team is looking into this.
Richard Tan
