Altera_ForumHonored Contributor13 years agoWriting the .flash file to flash on the target Greetings, I would like to do the similar functions that nios2-flash-programmer performs on the target. So I need to know what nios-flash-programmer does on the target. Does nios2-flash-pr...Show More
Altera_ForumHonored Contributor13 years agoNo, check this: http://en.wikipedia.org/wiki/srec_(file_format)
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
