12 years agoWriting latches in verilog
HI:
here is my code: module part4(SW,LEDR,LEDG); input[2:0] SW; output[2:0] LEDR; output[0:0] LEDG; assign LEDR = SW; assign Clk = SW[2]; assign R = SW[1]; assign S = SW[0]; wire R_g,S_g,Qa,Qb;/*synthesis keep*/ always @ (posedge Clk); assign R_g = Clk&R; // R&Clk assign S_g = Clk&S; // S&Clk assign Qa = ~(R_g|Qb); assign Qb = ~(S_g|Qa); assign LEDG = Qa; endmodule​ Here are the problems : 1: wire R_g,S_g,Qa,Qb;/*synthesis keep*/ Error: Warning (10885): Verilog HDL Attribute warning at DLatch.v(11): synthesis attribute "keep" with value "1" has no object and is ignored 2: assign Qa = Qb&S_g; assign Qb = Qa&R_g; Error: Their value just simply cannot be assigned . The line is red in model sim Thanks in advance .
