10 years ago
write code vhdl cruise control how ???
hello everyone:)
places anyone can help me to write code vhdl about cruise control :confused:???
thanks for any can help me:-P
    like I said, you need to include the source code for all of your components in your project
    You havent shown the source code for them here - so I assume you have them on your machine elsewhere. If the source code doesnt exist - you need to write it.
    There are many VHDL tutorials and text books out there - I suggest you do some research.
    I search many website try Execution code is same problem:(:confused:
    ----- File project.vhd: ---------------------
    2 LIBRARY ieee;
    3 USE ieee.std_logic_1164.all;
    4 ------------------------------------
    5 ENTITY project IS
    6 PORT (a, b, c, d: IN STD_LOGIC;
    7 x, y: OUT STD_LOGIC);
    8 END project;
    9 ------------------------------------
    10 ARCHITECTURE structural OF project IS
    11 -------------
    12 COMPONENT inverter IS
    13 PORT (a: IN STD_LOGIC; b: OUT STD_LOGIC);
    14 END COMPONENT;
    15 -------------
    16 COMPONENT nand_2 IS
    17 PORT (a, b: IN STD_LOGIC; c: OUT STD_LOGIC);
    18 END COMPONENT;
    19 -------------
    20 COMPONENT nand_3 IS
    21 PORT (a, b, c: IN STD_LOGIC; d: OUT STD_LOGIC);
    22 END COMPONENT;
    23 -------------
    24 SIGNAL w: STD_LOGIC;
    25 BEGIN
    26 U1: inverter PORT MAP (b, w);
    27 U2: nand_2 PORT MAP (a, b, x);
    28 U3: nand_3 PORT MAP (w, c, d, y);
    29 END structural;
    Error: Node instance "U1" instantiates undefined entity "inverter"
    Error: Node instance "U2" instantiates undefined entity "nand_2"
    Error: Node instance "U3" instantiates undefined entity "nand_3"
    Error: Quartus II Analysis & Synthesis was unsuccessful. 3 errors, 0 warnings
    Error: Quartus II Full Compilation was unsuccessful. 5 errors, 0 warnings
    Yes - you havent defined the behaviour for the components.
