10 years agowrite code vhdl cruise control how ???
hello everyone:) places anyone can help me to write code vhdl about cruise control :confused:??? thanks for any can help me:-P
10 years agoi try to isolation cruise control by method Components
i have this (Error (10465): VHDL error at cruise_control.vhd(31): name "cruise_on" cannot be used because it is already used for a previously declared item) -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY cruise_control IS PORT (cancel, accleartor, Rest, break, set, cruise_on, cruise_off : IN STD_LOGIC; setspeed: OUT STD_LOGIC); END cruise_control; ARCHITECTURE structural OF cruise_control IS COMPONENT crease_speed IS PORT (accleartor, Rest: IN STD_LOGIC; setspeed: OUT STD_LOGIC); END COMPONENT; COMPONENT increase_speed IS PORT (break, set: IN STD_LOGIC; setspeed: OUT STD_LOGIC); END COMPONENT; COMPONENT cancel1 IS PORT (cruise_off: IN STD_LOGIC; setspeed: OUT STD_LOGIC); END COMPONENT; COMPONENT cruise IS PORT (cruise_on: IN STD_LOGIC; setspeed: OUT STD_LOGIC); END COMPONENT; SIGNAL cruise_on: STD_LOGIC; BEGIN U1: crease_speed PORT MAP (accleartor, Rest, setspeed); U2: increase_speed PORT MAP (break, set, d, setspeed); U3: cancel1 PORT MAP (cruise_off, setspeed); U4: cruise PORT MAP (cruise_on, setspeed); END structural; ---------------------------------------------------------------------------------
