S_Poon
6 years agoWindows 10 runs into an exception and resets when trying to download RBF file to FPGA. There are no issues running under Windows 7. Have anyone encountered this problem? Is there a solution for this problem?
I am running Quartus Prime 15.1 under Windows 10, with 3 devices in the JTAG chain. The devices are in the following order : CPLD, FPGA, and CPLD. The CPLD devices in the chain can be programmed and ...
S_Poon
6 years agoHello Wolfgang, The newer versions of Quartus Prime that I tried includes 16.1, 17.1 and 18.1 they all do the same thing. When I try to perform any operation, I get an application
fault, with the following attached Quartus Prime Problem report. Or I get an error message from the Quartus User Interface, indicating "Device chain in use", with Error Code 44 or
Error Code 35. The devices in the chain are : 5M2210, 5SGXMA5 and 10M02. With Version 15.1, I am able to program and verify the CPLDs in the chain, just cannot perform operation with FPGA. This causes Windows to crash and resets the PC. Thanks.
