S_Poon
6 years agoWindows 10 runs into an exception and resets when trying to download RBF file to FPGA. There are no issues running under Windows 7. Have anyone encountered this problem? Is there a solution for this problem?
I am running Quartus Prime 15.1 under Windows 10, with 3 devices in the JTAG chain. The devices are in the following order : CPLD, FPGA, and CPLD. The CPLD devices in the chain can be programmed and ...
ShafiqY_Intel
6 years agoHi S_Poon,
I checked on Quartus Prime v15.1 Support Release Notes, Windows 10 is not supported Quartus v15.1.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-qts-std-151-dev-support.pdf
With newer Quartus versions CPLDs cannot be programmed or verified
May I know which CPLDs and newer Quartus version you are using?
