14 years agoHi,
Thanks for the quick reply. You're right, one can use generics to define the width of the std_logic_vector type. But it get's tricky if you want to use records to group signals of your port specification, for example, look at the code again:library ieee;
use ieee.std_logic_1164.all;
use work.math_pkg.all;
package fifo_pkg is
type fifo_in_type is record
data_in : std_logic_vector(DATA_WIDTH_??- 1 downto 0);
rd : std_logic;
wr : std_logic;
end record;
type fifo_out_type is record
data_out : std_logic_vector(DATA_WIDTH_?? - 1 downto 0);
empty : std_logic;
full : std_logic;
end record;
component fifo is
generic
MIN_DEPTH : integer;
DATA_WIDTH : integer
port
clk : in std_logic;
res_n : in std_logic;
i : in fifo_in_type;
o : out fifo_out_type
end component fifo;
end fifo_pkg; As far as i understood, there is no way to use generics in records in Quartus. So that i could link DATA_WIDTH_?? to DATA_WIDTH from the component declaration. But i could do this with the code i posted in the previous post, so i could instantiate fifos of various width and depth's, and could use records to group the signals. Sry for not being precise enough when posting this first... Thanks, T
