16 years ago --- Quote Start --- All Windows should be the same, but different than Linux compiles. --- Quote End --- I'll just add that 32-bit and 64-bit compiles will also give different results, again since the compilers are different. So win32, win64, lin32 and lin64 will all give different answers from one another, but (as Rysc said) these are just equivalent to a change in seed. Just to reiterate what everyone else has said: yes, if Quartus is run twice on the same inputs on the same OS, it will always give the same results. Adrian Ludwin Altera Corp.
