10 years agoWhy there is no device model for EPM1270GM256 in quartus?
I am going to use the CPLD EPM1270GM256, but I cannot find EPM1270GM256 device in quartus.There is EPM1270M256,but not EPM1270GM256.How to solve this problem? Wishing for your help!!Thank you
10 years ago --- Quote Start --- See "are the programmer object files (.pof) for max® ii and max® iig devices compatible? (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12212005_320.html)". In short, you've found the right part. There aren't any MAX IIG devices available to select from in Quartus. You need to choose the EPM1270M256 part you've found. Cheers, Alex --- Quote End --- Thank you for your reply!
