Altera_ForumHonored Contributor13 years agoWhy the task cannot be synthesisd? I just try to use a task to improve the programming efficiency. The code is as following: task TwoNumberMin; input [RamWidth-1:0] a,b; input clk; output [RamWidth-1:0] min; always...Show More
Recent DiscussionsDesign Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]Highlight similar instances of a selected word fails when scrollingSolvedWarning at Standard 25.1 by Arria 10
