13 years agoTry:
task TwoNumberMin; input [RamWidth-1:0] a,b; input clk; output [RamWidth-1:0] min; begin always @(posedge clk) begin if (a>b) min<=b; else min<=a; end end endtask I find if there is a problem it is quickest to use a search engine for the construct you are having syntax problems with. In this case: "verilog task" brings up lots of helpful answers. It would be nice if the error messages from the tools were more helpful too! (Often the error is in the previous line - not the line that gives the error message.) ++Simon
